I know this is off the wall but I will be willing to bet you it happens more often than never.
Say you wire a new house. You wire each room on its own circuit or even combine them to cut down on the cost of buying AFCI breakers. Well in your wiring you pick up a feed to power the smoke detectors from the bedroom. Here's my problem with this.
A loose connection in an outlet that an small heater or what ever (you name the load) starts to show fault. Before the AFCI can trip, a small fire starts, by this time the AFCI does it's job and trips the breaker, which also kills power to the smoke detectors. Batteries in the smoke detector have not been changed in years. I know its the owners fault for not changing the batteries since most fire departments in my area give them away for free when the time changes.
I just think its a valid point to not pick up the feed for smoke detectors off circuits feed from AFCI breakers. I know this is reaching far but I would think that any of you out there would agree that this could happen.
Id love your input.
Id love your input.
