czars
Czars
- West Melbourne, FL
- Florida Certified Electrical Contractor
2/21/2014
I wanted to share what I have learned over the past few days by talking to Schneider (Square D), Eaton (Cutler Hammer) and Siemens about AFCI breakers as well as Leviton about AFCI receptacles.
Schneider/ Square D
1. Schneider does not manufacture a 2-pole combination AFCI breaker, but they are in development.
2. They do make single pole combination AFCI breakers and they do not contain any ground fault detection capability.
3. Schneider also manufactures single pole, ?Dual Function? devices that do contain both a combination arc fault detection and a ground fault detection capability. These devices are identified as: QO115DF, QO120DF, HOM115DF and HOM120DF. Apparently these breakers can provide both AFCI and GFCI protection for circuits like kitchen countertop receptacles as required by the 2014 NEC.
Eaton/Cutler Hammer
1. Eaton manufactures both single pole and 2-pole, combination, AFCI breakers for the BR and CH panels.
2. In the 2009 timeframe, and probably before, the single pole AFCI breakers contained a ground fault detection capability which had a threshold at about 30ma. However, the currently manufactured AFCI breakers have been ?improved? and no longer contain any ground fault detection or protection capability.
3. The 2-pole breakers do not contain any ground fault detection capability and are suitable for use on MWBCs.
4. The BR AFCI breakers are not suitable for use in Westinghouse, Challenger or Bryant panels.
Siemens
1. Siemens manufactures both single pole and 2-pole, combination, AFCI breakers.
2. The single pole, combination, AFCI breakers that are currently manufactured do not have any ground fault detection capability.
3. The 2-pole breakers do not contain any ground fault detection or protection capability and are suitable for use on MWBCs.
4. The Siemens breakers are suitable for use in all Siemens, Murray, I-T-E and Crouse-Hinds panels.
Leviton
1. Leviton manufacturers both 15A and 20A combination AFCI receptacles. They are identified as: AFTR1-(letter for color).
2. The receptacle contains no ground fault detection or protection capability.
3. The receptacles are available from a number of sources including Amazon for about $26.
Schneider/ Square D
Eaton/Cutler Hammer
Siemens
Leviton
