The GE single pole combination-type AFCI that can be used for multiwire branch circuits has the designation "MOD 3" on the face of the breaker near the handle. They've been available here for several weeks now. The interesting thing about them is they don't need the load neutral connected to them.GE is supposed to be coming out with 1p breakers than can be used on MWBCs with the use of a handle tie.
I don't recall actually seeing that the ground fault detection is part of the AFCI performance requirements. The microcircuitry and software that does the arc discrimination is evidently meeting the performance requirements of a combination type AFCI all by itself.That is surprising, I wonder how it knows a ground fault from a line to neutral load.
Pay close attention to Dennis' linked diagram from GE, and the way the load neutral from the multiwire branch circuit is connected to only one of the two GE single pole AFCI breakers.I have put in a 2-pole 15 AF breaker from GE on the house I am working on. The 4 other panels are Square D and they do not make a 2-pole AF.
Until the GE MOD 3, that has been true. But I suspect that was because the manufacturers still weren't giving us a product that could actually meet the AFCI performance requirements without the kludge of a signal processing arc descriminator and a ground fault detector.It may not, I just know the combo units I've installed have gfi detection also, not 6ma.
I know sq.D homeline doesn't make a dp afci but I don't know about their QO series.I have put in a 2-pole 15 AF breaker from GE on the house I am working on. The 4 other panels are Square D and they do not make a 2-pole AF.
