zstarch
- Charlotte, NC
I am upgrading a large residence to AFCI and tamper proof receptacles .
Question;
In kitchen and baths, it seems I can go two ways;
1. Remove the existing GFCI recept and replace with tamper proof GFCI and install AFCI in panel
2. Replace Local GFCI receptacle with standard tamper proof recept and put dual function AFCI/GFCI breaker in panel
It seems, since I would have to replace the local GFCI with tamper proof GFCI, along with the other receptacles, option 2 might be easier and cheaper. Is there any code preference or other consideration here?
Second. Can I replace the receptacles in these areas with 20 amp versus 15 amp if the branch circuit is 20 amp breaker with #12 wire? It seems they would be better for hair dryers, toasters and other high current loads. Or can 20 amp only be used where there is a single receptacle on the circuit like a washer or fridge?
General note. The panels are Square D QO 200 amp (two of them) All wiring is either in EMT or MC cable and metal boxes.
Question;
