Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
If you had a choice which brand would you install for residential that has the best reliability of GFCI/AFCI breakers.
Most likely a moving target as offending inverter appliances saturate the market, and xFCI firmware & shielding are adapted.If you had a choice which brand would you install for residential that has the best reliability of GFCI/AFCI breakers.
If helpers wont read listed instructions or follow diagnostics, any circuit breaker beyond Thermal Magnetic is too complex.I like the N.O.N.E. brand if it includes AFCI!
