Will a GFCI receptacle work properly if it is fed from an AFCI breaker?
N nizak Senior Member Dec 17, 2010 #1 Will a GFCI receptacle work properly if it is fed from an AFCI breaker?
jxofaltrds Inspector Mike® Location Mike P. Columbus Ohio Occupation ESI, PI, RBO Dec 17, 2010 #2 nizak said: Will a GFCI receptacle work properly if it is fed from an AFCI breaker? Click to expand... If wired properly.
raider1 Senior Member Staff member Location Logan, Utah Dec 17, 2010 #3 Yes a GFCI receptacle will work installed on an AFCI protected circuit. Chris
