I know im nitpicking but a common
Hallway in a 4 family is not really
In the dwelling unit. Afci or not ?
I would call it four dwelling units not in a large non-dwelling box but in a large box designed to hold dwelling units. The box is residential in character where that makes a difference in the code, but is not by itself a dwelling unit. The latter is defined specifically as a separate unit which may be either standalone or part of a whole.Its all on house panel lighting circuit but whats fuzzy to me is the whole 4 family a dwelling unit or is it 4 dwelling unit boxes in a large non dwelling box
Putting aside what the code REQUIRES, an AFCI would seem to be DESIREABLE on ALL circuits. Any circuit, whether in a bedroom or a hallway or even places where AFCIs are not required, would seem to benefit. (Well not the circuit, but the people living there would be the beneficiaries.) The whole idea of the AFCI is to prevent fires from any arcing. I'm guessing there was push back from builders (for good reason....they need to keep costs down) which lead to the specific requirements in the code, permitting some areas to not be AFCI protected.
I am now seeing combined AFCI/GFCI units which would seem to be very useful, for example, in a bedroom which is currently equipped with two blade receptacles and without any ground wire. The GFCI function would permit the installation of 3 blade receptacles, and the AFCI function would provide the arc-fault fire protection.
Question: Does anyone have any experience with the combined (AFCI/GFCI) units?
All I can think of is it probably has at least 396 less doors in it.Why would a common hallway in 4 apartment unit be any different than a common hallway in a 400 apartment unit? Either way you're not within the dwelling units.
