overmyhead
I would like to update the wiring on an older home-ie. new panels and new grounding type plugs. The existing wiring is two wire only, of course I will be adding a ground rod etc... but I will not be re-wiring branch circuits. I know the code allows GFI feeding 3 prong outlets with only 2 wires. But I would like to use AFCI instead to comply with NEC 2008. So the queston is should I stick with the letter of the code-GFI? Or should I follow the spirit of the code-AFCI? Or do I have to do both? Is this going to be changed withg NEC 2011 anyway?
