lbwireman
- Long Beach, CA
Hi All,
We just finished trimout on a 500 sq ft Bedrm/bathroom/wardrobe room addition for a customer. Our local AHJs previously went with a "soft" interpretation of NEC Art. 210.12 and only required that receptacle outlets in bdrms be AFCI protected. They have now switched to a "hard" interpretation, in accordance with the Art.100 definition of "outlet". We are now required to AFCI protect ALL outlets in the bedroom (including lighting). Problem: In this addition we put all outlets subject to this Art. on one circuit fed from an AFCI breaker in the main load center (new Murray 200A side by side combination panel). There is a ceilngfan w/ light kit receiving its 120V power through a hard wired SPST switch. The ceiling fan speed and light kit dimmer are controlled by a built-in remote receiver and a hand held remote controller. There are 4 incandescent can lights receiving their power through a switched dimmer. There is a flourescent ceiling luminaire in the wardrobe. The AFCI OC device remains set until a load is put on the circuit (energize any of the switches) at which time, the luminaire(s) will come on for about a half second then the AFCI trips. This also happens if an incandescent floor lamp is plugged into the first receptacle outlet in the circuit and turned on. Any thoughts? Thanks in advance.
Sean
Sean
