scwirenut said:but also a closet in a foyer dosent now make a foyer a bedroom, now we are right back were we started..lol
cowboyjwc said:Roger.
He can require it because by definition it is not a bedroom if it doesn't contain a closet with a pole.
cowboyjwc said:Other wise we would be calling the living room a sleeping room too. How many people fall asleep in front of the TV?
allenwayne said:This closet light in a bedroom was a long winded thread not to long ago.If my memory serves me well,the issue of it is required to be afci protected was contingent upon the switch being utilized as a point of utilization.The switch if a lighted switch would require the circut to be afci protected but if a standard SPST switch it would not.I believe this issue was never resolved.
To me once you enter a bedroom through the door and unless you enter a bathroom that requires other standards . The closet door still keeps it in the confines of the bedroom......I`m sure I`ll get flack from this statement !!!!
Cavie said:The original question was "should the receptical also be AFC and the answer is YES. ALL bedroom circuits shall be on AFC, including the BEDROOM CLOSET. The key word here is BEDROOM. Reciptical outlet not required but if installed it must be on AFC.
allenwayne said:Lets say that there is a sitting room as part of the bedroom.It is only accessed from within the confines of the bedroom.Is this part of the actual bedroom and required to have AFCI protection or do you consider it another room all together ????
To me it would be part of the bedroom and require AFCI protection.Same as a closet within the confines of the bedroom.Now a bathroom is called a bathroom since it is a seperate room all together but a bedroom closet is called a bedroom closet since it is within the bedroom.JMHO.
Jim W in Tampa said:Its really easy.Look at the print,it says what each rooms intended use is.Could we sleep in the living room ? Yes but its not required to be afci protected.Can you sleep in closet or bathroom ?
NEC says bedroom not bedroom closet.
I had to wire a home last year that print said was rec room or something like that for 2 room off a hall with a bath.I tried my best to get owner to go for afci and smoke detectors.Even the inspector didnt like this.I was hoping he would force them to be installed.They had no closets so had to let them go.Sick part was the owner told me they were mostly for his grandkids when they visit.He could easily have afforded them.Bottom line is we must go by the print.If that print says the little room off master bedroom is a bedroom then we wire it as one.We all have seen closets bigger than some mobile homes 3rd bedrooms.
