Re: AFCI Protection
This as edgy as it gets !!!!
96 code - receptacle outlets to be afci protected
02 code outlets to be afci protected
Both in dealing with bedrooms.100 gives us the definition of an outlet which leads to more rebutal is a switch a point that derives power.
In MHO yes without that switch the light receptacle fan blah blah blah can`t be ustilized from that room with out utilizing it IE; hitting a switch
When 02 cycle was adopted here we were informed by letter and a meeting that from the day of adoption of the 02 code all receptacle outlets,switches in a bedroom WILL be afci protected,changing to outlet leads to 100 and there fore a switch is a point that is used to utilize power.
I thought the whole thing stupid but all I am is a dumb sparky 1st a receptacle outlet now a receptacle,switch,smoke detector anything used in that room called a bedroom shall be afci protected.The question came up about closets in a bed room and we were told if the closet is in the same room as the bedroom afci.Now if you can access that closet from another door technically it is not in the bedroom since the lights can be turned on from a non afci room.but if there is a switch 3 way in this case afci it
