210.12 Arc-Fault Circuit-Interrupter Protection.
(A) Dwelling Units. All 120-volt, single phase, 15- and
20-ampere branch circuits supplying outlets installed in .....
I think the reason its mentioned 120 Volts bc all of US house outlets are 120 Volts single pole.
This doesn't mean if the voltage is 220 Volts line to neutral that it's OK to have the circuit on normal CB right?
