hello, I am new here although I have been reading a lot of threads recently. I am retired and have not worked as an electrician for a while, and some codes have changed.
Will a dual GFCI/AFCI receptacle mounted next to a circuit panel, connecting a circuit to the load side pass an inspection in most cases to meet the GFCI/AFCI code?
If so are there any problems with false tripping with these new devices? I have a hunch that I should spend extra money on dual-function AFCI/GFCI circuit breakers that will perform better without tripping falsely.
thanks.
thanks.
