michaelbluejay
- Austin, TX
- Rental property maintenance
I know that NEC requires AFCI breakers for bedrooms, but not attics.
What if the appliance is in a bedroom, but it's plugged into a receptacle outlet in an attic?
I have a small 115V mini split head with a plug (not hard-wired). My choices are:
(1) Cut in an outlet box into the ceiling. Definitely requires an AFCI breaker, which is safer, but I'm wary of nuisance tripping, so I prefer to avoid the AFCI if I can.
(2) Install the outlet box in the attic, and run the power cable/plug up through the ceiling to the attic. Uncertain whether I need the AFCI.
If I need the AFCI either way, then I'll go with option 1, since it's cleaner.
I imagine the answer is going to be, "Whatever the local inspector says they want."
