jeff43222
- Minneapolis, Minnesota
I just got hired to do some ceiling fan stuff for a friend of a friend. I'm not sure how many AFCIs are needed in this scenario, so I thought I'd let the experts weigh in.
He wants a new ceiling fan installed in the baby's bedroom. There is no light outlet in the ceiling right now; the room has a switched receptacle. The plan is to make the switched receptacle unswitched and control the new ceiling fan from a new switch in the existing switch box. Since this is a new outlet, I will be replacing whatever breaker is protecting the switched receptacle and putting in an AFCI breaker so the fan/light will be protected.
In the master bedroom, there is an existing ceiling fan, but the only control for it is a battery-operated remote control. Apparently the fan/light fixture is hard-wired to a power source somewhere. He wants to keep the existing fixture and have me wire in a couple of switch loops so the fan and light can be controlled from new switches in the existing switch box (and the switched receptacles will be converted to unswitched, like in the baby's room).
I'm wondering if the master bedroom work will require an AFCI breaker. It's not a new installation, just adding switch loops to an existing outlet. The panel wasn't labeled well, so I don't know if both bedrooms are on the same circuit.
