AFCI Switches
scootk70
Allentown, PA
Leviton Combination AFCI/Switch
What wiring method for installation. :?
Ckd 2011, 2014?
210.12(A)(4)?
Connect existing wiring to combo. AFCI switch and you're done?
Ckd 2011, 2014?
210.12(A)(4)?
I wonder if your allowed to backstab them ? :blink:
At least they provide a good indication of reasons for using the switch, including when the first outlet (well to avoid arguments we will say the first device) on an existing branch is a switch.
That is the first I have seen of this product
Yea but who want's all their receptacles switched:p
From the description, I suspect that the unit has unswitched pass through protection (15A) as well as a switched output. But if that is the case it apparently does not interrupt the neutral the way a GFCI receptacle does OR there are more screw or back wired terminals than show up clearly in the pictures. I would like to see the instructions.
My guess is that it uses the EGC as a return wire to power the electronics. (One more step backwards....)
Very cool, and long over due. IMO this combination switch / AFCI and the blank face AFCI should have been part of the original product offering. The needs in remodel wiring are that obvious.
