Re: AFCI Tester
If you install a piece of equipment, and test it, you may never know if that piece of equipment will function the same again when needed, but doesnt it make you feel better in a sence that it worked when you left and that you did your job correct. what if you didnt test it, it fails at a later date, someone dies, and you didnt test something that can be tested. This is why we will do a walk through with the customer at the time a job is done, to document with the customer that when we are done, our work is complete and tests that can be done, are done, and "pass" some sort of standard. Luckily here in MI, we dont need to install AFCI's yet, becuase it is not been adopted in the MI resi code. Maybe next year.
