i have a new house that has a afci tripping issue. I discovered it when i tried to plug my cable coax into my computer for tv. It tripped the rooms afci. Of course, right away the electrician tells me it's a problem with my computer, but after many hours of testing i discover that if anything is plugged into any outlet on the afci circuit, then a coax touches the item, such as a surge protector with coax protection....the afci trips. It only happens on this circuit. I have plugged the same surge protector into other rooms with afci breakers and connected the coax to it with no trouble. To make things more confusing...I have an external hard drive that when it is plugged (three prong plug) into the room with the afci problem and connected to the usb port of the computer all is okay, but if the ext hard drive is plugged into the other rooms circuit (different afci breaker than problem one), then the afci breaker trips in the computer room when the usb touches the computer. The electrician has replaced the afci breaker with the issue, but wants to replace it with a regular breaker that doesn't trip when coax attached to items.
Anyone have thoughts on this. An help would be appreciated. I really don't want to just "bypass' the issue with a regular breaker since something is different about this circuit. I have opened the outlets and light switch to see if any neutrals may be touching grounds or issues, but have not come up with anything yet!
Thanks,
Mike
Thanks,
Mike
