Hello,
I am having an issue with an AFCI that makes me scratch my head.
Was asked to looking at why the breaker trips when the bathroom light is turned on. House is less than a year old, circuit has worked fine until now. Verified it wasn't the switch then started checking joints and found nothing. What I did realize is that if I removed several of the lamps from the bath fixture (8 lamp "standard" vanity light), then I could turn the light on and the circuit would hold. So I verified there wasn't something on the circuit overloading it. All that was on was the bedroom fan/light and the bathroom light. When I add more load to the circuit via the closest light, tv, lamp, or another bulb in the bath light the AFCI trips.
So I am seeing the AFCI trip not when overloaded, or when any load is on but only when loaded to a certain point. (Haven't taken an amp meter to it yet to verify the exact amperage at when this happens)
Before purchasing a new $40 breaker I just removed the circuit from another AFCI breaker and attached this circuit to it. To see if it would trip that breaker (which has been working fine) and it did in fact trip that breaker. I have a brand new breaker that I am going to try but I am not convinenced that it will work.
Any thoughts on something I may be missing would be appreciated.
Thanks
Thanks
