Perhaps someone here can shed some light on 2 AFCI questions that I appear to be getting mixed answers from lighting control manufacturers?
From what I?ve read when dimming a AFCI circuit one should not exceed 1000W as far as the dimmed load ? but my question is when one is using say a lighting control power module (and I guess as well this question applies for general circuits as well) should I still be able to use the remaining wattage for switched loads? I?ve received mixed answers from lighting control manufacturers (not sure if they know the answer or not honestly).
Second question - in instances where one is controlling a fan/light combo on an AFCI breaker ? we need to ensure that the loads are sharing a neutral. In order to do this (in centralized lighting control system applications) the AFCI breaker has to be shared between the lighting module and a fan speed control module. Are there any reliable ?2 pole breakers? that will allow one to maximize the potential wattage output of power modules while at the same time provide a shared neutral (instead of trying to squeeze providing power to 2 modules with one breaker)?
Thanks.
Thanks.
