sparky_magoo
- Reno
I made up a panel today and realized a huge mistake. From the panel, I have conduits run under the slab, to junction points.
I have a conduit to the master bath which terminates in a 3 gang masonary switch box. I ran a multi-wire ckt. to this box to power the master bedroom receptacles and the master bath GFI ckt. My question is, how can I possibly power an AFCI breaker for the master bedroom ckt. with a shared nuetral on the master bath GFI ckt. The owner of my company told me to do it this way, but I feel it is my responsibiliy to detedt any incompetance and correct it before any wire is pulled.
Can I make this ckt. work? Wouldn't unbalanced current from the GFI ckt. cause the AFCI breaker, for the bedroom, to trip? This is a long pipe run. I would have to pull all of the wires out and re-pull with an additional nuetral conductor. I am already maxed on pipe fill.
Does anyone make a 2 pole AFCI breaker? This is a CH commercial panel (22' wide, forty slots).
BTW, are CH AFCI breakers listed for use in a commercial panel? I am new to this shop. I am not used to their ways. Running conduit under the slab to feed branch ckt.'s is new to me.
