Re: AFCI
Originally posted by dmullaney:A switch does not TAKE current, but instead it either opens or closes an electrical circuit thet supplies current to utilization equipment. The local inspector disagrees. What's your opinion?
I agree with you. Furthermore, I believe there is no reasonable basis for the inspector?s position. I support my stance from two perspectives.
My first perspective is that of the English language. Unless and until it is proven inappropriate for a specific case, I believe that we must credit the authors of any code with having carefully and thoughtfully selected their words. We do not ?take? current at the switch to supply ?utilization equipment.? Rather, we pass current through the switch to supply an outlet that is located in the bathroom. At that outlet, we take current to supply a light or a receptacle. Therefore, the switch is not an ?outlet,? as defined in the article that you have quoted.
My second perspective focuses on the hazard that we are trying to alleviate, the dangerous situation that we are trying to avert. Why does the code require us to install an AFCI to protect outlets in a bedroom? My answer is, ?To prevent fires from being started by frayed extension cords, or by cheap and shoddy light fixtures.? But you cannot plug an extension cord into a wall light switch. You cannot hang a wall-mounted light fixture on top of a wall light switch. Nothing protrudes from a wall light switch except the switch handle. But that handle is plastic, and cannot be a participant in an arc fault. Therefore, there is no technical reason for including the wall switch in the AFCI circuit.
The best perspective on this question, however, I can no longer offer, since I am no longer a member of the NFPA. Any current member can get information from the technical committee discussions that led to the change in the 2002 NEC. Those discussions may well include a clear statement, on the part of the code authors, regarding whether they intended to include a wall switch in the AFCI requirements. Any NFPA members present who would like to give it a go?
