paul renshaw
- Cordova, Maryland
Is a walk-in closet off of a bedroom considered to be bedroom and require afci protection?
The "125 volts" is the rating of the receptacle and of the outlet into which the receptacle is installed.
as you say !The NEC doesn't define either room. So a closet isn't a bedroom. But it's possible that a jurisdiction might define the rooms and apply the NEC using those definitions.
I have to agree there.Originally posted by jimwalker:
Using there logic do they include the master bath ?
The closet is not a bedroom - I agree. But the closet is in the bedroom, therefore an outlet in the closet within the bedrrom is essentially in the bedroom. My interpretation.Originally posted by physis:
210.12(B) Dwelling Unit Bedrooms. All branch circuits that supply 125-volt, single phase, 15- and 20-ampere outlets installed in dwelling unit bedrooms shall be protected by an arc-fault circuit interrupter listed to provide protection of the entire branch circuit.
I wonder where they get 125 volts from. Maybe it's a loop hole.
If you go too far with that logic you might end up with the whole house in the bedroom.But the closet is in the bedroom
I take issue with this.Originally posted by nedard2004:
I agree with jimwalker. It's a bunch of garbage how alot of the inspectors interpret things. Our inspector does not require the lighting and/or smoke detectors to be AFCI protected in bedrooms. The last time I checked, the NEC is the minimum set of requirements to follow...inspectors can add to those requirement, but cannot take away. None the less, I go adhere to NEC rules instead of what the local says we can do.
