Jimmy7
- Boston, MA
- Electrician
Do I need an Afci breaker here? I was hired by a customer to replace three existing ceiling fixtures with recessed lights that are all switched together. The house was built in the 50’s and the lights are located in the first floor ceiling, so there is no attic above. Between two of the fixtures I had to replace a damaged cable, and the run of cable was probably exactly 6’. I figured I would just install an afci breaker in the Square D QO panel and be done. Unfortunately, the panel was full of tandem breakers, and the circuit I needed was on one and was also part of multi-wire branch circuit. The circuit was the black of a three wire at the panel. What do you do in cases like this? Is there a way to afci a MWBC?
