AFCI
Re: AFCI
2005 cycle
210,12 (B) Dwelling Unit Bedrooms. All 120-volt, single phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit bedrooms shall be protected by a listed arc-fault circuit interrupter, combination type installed to provide protection of the branch circuit.
2002 cycle
(B) Dwelling Unit Bedrooms. All branch circuits that supply 125-volt, single-phase, 15- and 20-ampere outlets installed in dwelling unit bedrooms shall be protected by an arc-fault circuit interrupter listed to provide protection of the entire branch circuit
Re: AFCI
Your using the 99 code book.
If that is the code you're under, then receptacles are all that is required to be AFCI protected.
BTW, please turn off your CAPS, it is considered yelling.
Roger
Re: AFCI
sdnoga: Please turn off the ALL CAPS feature. It makes the post more difficult to read. It is also considered impolite, as though you were SHOUTING at us.
