roy anderberg
Why does the code require that the smoke alarms be wired into the AFIC circuits? And yet they allow that the outside GFI's be connected to the same circuits also.
roy anderberg said:Why does the code require that the smoke alarms be wired into the AFIC circuits? And yet they allow that the outside GFI's be connected to the same circuits also.
Roy said:The inspector in Washington State made me put the detectors on the bedroom arc-fault, and that's what I have been doing ever since.
I hope it doesn't come to that. As long as AFCI-like incidents don't keep recurring, it shouldn't.dnem said:It's possible that states could move into enacting their own completely seperate electrical building codes. . If some states start to move away from adoption of the NEC, it could draw others into doing the same. . NFPA 70 could end up like NFPA 72, just a resource that the state uses to write its own code.
georgestolz said:I hope it doesn't come to that. As long as AFCI-like incidents don't keep recurring, it shouldn't.
All the same, it might wake them up to the realities of their position.
Isn't that somethin'. I have great faith in the "technological" solution to many things, but arc fault technology is not one of them. The manufacturer's silence about their individual hardware solution's structure and logic is so LOUD. . .don_resqcapt19 said:If things continue as they are now the AFCI requirement will go away all by itself. There are no products on the market that meet the 1/1/2008 requirement and it is not likely that there will be, so the section will become void as there is not a product that can comply.
Don
