justdavemamm
- Rochester NY
Listening to home DIY advice show on a local radio station this Sunday morning. (Rochester NY - 2008 code IIRC)
The guest electrician takes a call about installing a GFI on a two wire (ungrounded) circuit. At first he says that the GFI will generate a ground. Then he says that the circuit, after the GFI, feeding an outlet recept. that has a ground hole, you are permitted to connect the neutral to the ground terminal on the recept.. That this is the only case where this is allowed.
No mention of placing a sticker on the downstream indicating that it is ungrounded, or fed from a GFI.
Right or wrong ? I was under the impression that it was NEVER ok to jumper the ground to the neutral there. Is there an exception for GFI's?
