Scott66
New member
- Monroe, Ga. U.S.
I need some help with this situation. I'm working in a fast food restaurant adding two new circuits. I open the panel that I was told I needed to use and see that it is being supplied by a 60 AMP single pole breaker. This panel is a single phase panel and what the previous electrician pulled 3 #6 wires to this panel 1 hot, 1 neutral and 1 ground. Then they took the hot wire to A phase then used a jumper from A phase to B phase so that they have both A phase and B phase. I feel like this is against code, I'm I right or wrong. I have been looking in the code book and can not find anything on it yet. Thanks, for your help.
