ryanpickett2003
- Hilliard, FL, Nassau
I'm replacing an existing 400 amp service on an agriculture building with a new 400 amp service and will be installing a Service Rated transfer switch and wiring to a 60 kw generator. My question is regarding the wire size i need to install at the service. I will be installing two 200 amp breaker disconnects next to my TF switch that will feed the existing panels. Can I use 4/0 aluminum or will I need 250mcm? I ask because all the ag buildings I've worked in used 4/0 for the service but I can't find where I would be allowed to by the NEC. Thanks
