sergiyny
- Brooklyn, NY
Typically when I get mechanical drawings, I see some condensing unit on the roof which supplies a few air handler units in the office space. AHU's draw about 1 amp at 208V and I usually provide 2 pole manual motor starter for them. This time mechanical engineer showed on plan an AHU and a box right next to it with power requirements and a line with "Factory D.S: YES". Do they need a disconnect switches? Where do you install them? If AHU does not come with factory d.s., does it still need a d.s. or should it just be 2 pole motor starter?
