I usually use the max breaker size and size the wire based on that. The customer Has a 45 amp breaker with 10 awg wire. It’s hard to read but it looks like the minimum ampacity and fla of the equipment contradict each other. Would the minimum circuit ampacity supersede the fla based on the unit isn’t running at full capacity? If so would it just be a breaker change for the 10 awg wire?
