BrianJay
New User
- Palm Springs CA
- Residential Electrician
The residence I am working at for a customer currently has a 60a circuit for one air conditioner and right next to it is another air conditioner with a 40 amp breaker. Both units are behind the garage. But now, They would like to have a 40 amp car charger installed.
Both A/C units are being replaced with two new units. Name plate :
Minimum circuit amperage 26.9
Maximum BKR 40 amps
The main panel is not really near by for the new car charger to run a new circuit.
So...Could I put in a sub panel, (using exiting 60 amp), with two 40 amp breakers each feeding the new a/c units. and then use the old 40 amp for the car charger ?
My only confusion is that new A/C units are very efficient and have smaller wire gauge specs than that of a regular circuit.
Summary: From the main panel a 60 amp feeding a new sub with two 40 amp, each feeding new A/C units. And old 40 amp from main feeing car charger. ?
Maximum BKR 40 amps
