We're working on a Condo with a 3 ton AC compressor spec'd for a max 25 amp circuit breaker/ AC disconnect switch. Please let me know who make a 25 Amp two pole AC disconnect rated for NEMA3R outdoor use. We prefer Square D QO but are only finding 30 and 40 amp AC disconnects. The current AC disconnect is over rated and the box is rusted out so we're replacing it while doing other work on the Condo. It's a 3 ton Ducane AC compressor.
Thanks
Ducane Model: 2AC13L36P-2B
R-22, Split AC unit, 13 SEER, Louvered, 36,000 BTU, 208-230 v/60hz
Did this once before on an earlier post..... I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work. Rocket scientist are not among those permitted.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
The nature of your post and your profile do not appear to me the requirements for this Forum.
