DM2-Inc
- Houston, Texas
We provided a fire & gas system to a project in small town in New York.
When we went to turn it on and test it, we noted water had filled several devices on the exterior of the building. The conduit enters the device from the side and there is no Low Point Drain on the conduit entering the box. The conduit drops down to a GUAT and then from the side of the GUAT it ties to two Strobe lights that are about 9" from the GUAT.
Someone is telling me they believe this to be condensation, and that there is a requirement when mounting junction boxes with an air gap when mounting them to exterior Brick or concrete walls. These device connect to an addressable output module that's installed in a 3' x 3' NEMA 4X box. The conduit from the box runs about 20' horizontal before running down about 5' to the GUAT mentioned above.
I'm trying to find a code reference for the Air Gap requirement, however it does make sense considering the difference in temperature from the inside of the building and the exterior of the building. The walls aren't insulated on the inside of the building.
Someone know the code reference?
