Trowbridge - Martin
This is an update to earlier post:
An A.H.U. air handler unit is in a second floor hall closet space for itself. There is a disconnect (circuit brkr) in the garage main panel not within sight and more than 50 feet away from AHU. The AHU has a built in disconnect (circuit brkr) accessable on front of unit. Does there need to be an additional disconnect on the wall of the closet space prior to the unit also? The AHU built in disconnect works good for sevicing the unit but not at all when unit is replaced.
Please give code sections or just great comments. Thanks
