kbsparky
- Delmarva, USA
I am looking at some plans/specs for a proposed aircraft hanger.
In the specs, they are calling for the installation of a static electrical grounding system, and referenced NFPA 409.
In each bay of the hanger, they are calling for (2) floor mounted grounding receptacles, where one would plug-in a ground wire and attach it to the frame of the plane to prevent build-up of static electrical charges.
They want cad-weld connections on the whole system (expected this) and a boat load of ground rods behind the hangers, all of which are interconnected and cad-welded together.
Now for the "what was that?" part:
HUH??
Wouldn't the use of PVC conduit kind of diminish the effect of obtaining a good ground of the bare wire in contact with the concrete and/or earth?? I would have thought that the more contact with the soil, the better ground. What am I missing here?
Have any of you had experience with aircraft hangers, and the installation of static discharge grounding systems?
.... the bare copper wire used to connect the grounding system to the devices, in or under the slab, on grade shall be enclosed in PVC conduit.
HUH??
