Isaiah
- Baton Rouge
- Electrical Inspector
Does anyone out there know if NEC govern US airport construction?
A few cycles ago the NEC lowered the voltage and tightened up the requirements for non shielded MV conductors. They do have an exception which still recognizes 5 KV series connected airport lighting cable. But that doesn't mean these systems are entirely NEC compliant, I certainly don't know.Runway lighting is a special case that I don't think is covered in the NEC.
I don't see anything in the NEC that excludes runway lightingRunway lighting is a special case that I don't think is covered in the NEC.
Most of the time, government excludes itself from the local building regulations. They usually adopt the NEC as an internal rule, and sometimes even use local inspectors. But for the most part they are not subject to the same rules the rest of us are, so they can pick and choose what they want to do.I don't see anything in the NEC that excludes runway lighting
There are two ways the NEC covers something. One is by law. The state or a local government passes a law saying so. They usually exempt government entities from this requirement.NEC 90.2 defines what is and what is not covered by the NEC. Good time to read it if you are unsure.
The other way is by rule, written into a contract. This is usually how the NEC comes to apply to government work.
If it is not done one of those two ways the NEC as whole does not apply at all. You only get to article 90 after the NEC applies.
And what I recall the runway light fixtures are wired in series just like the old Xmas tree lights!Runway lighting is a special case that I don't think is covered in the NEC.
Runway lighting is typically series and rules for series lighting was added some code cycles ago. I was instructing at a naval air station and the person who did the runway lights didn't think they were in the NEC, so I remember when they were added, but now I don't know what section they are in. But its special wiring, few electricians have ever seen itA few cycles ago the NEC lowered the voltage and tightened up the requirements for non shielded MV conductors. They do have an exception which still recognizes 5 KV series connected airport lighting cable. But that doesn't mean these systems are entirely NEC compliant, I certainly don't know.
In WA, government agencies are under the NEC, with permits and inspections, but the federal government is not subject to state rules. A government can exempt itself from the NEC but its rules have to equal or better, so some cities have there own rules that adopt the NEC and make changes. Example, Aberdeen WA near the coast, does not allow aluminum wiring due to corrosionMost of the time, government excludes itself from the local building regulations. They usually adopt the NEC as an internal rule, and sometimes even use local inspectors. But for the most part they are not subject to the same rules the rest of us are, so they can pick and choose what they want to do.
Yes, but if I recall correctly, each fixture has a saturating-core transformer so that all the other lights remain lit when one burns out.And what I recall the runway light fixtures are wired in series just like the old Xmas tree lights!
I agree the wiring is unconventional in that the lights are in series, however I'm not sure the NEC does or really needs to give any guidance on it. As far as I know, the only NEC reference is in 310 which has an exception to the conductor shielding requirements.Runway lighting is typically series and rules for series lighting was added some code cycles ago. I was instructing at a naval air station and the person who did the runway lights didn't think they were in the NEC, so I remember when they were added, but now I don't know what section they are in. But its special wiring, few electricians have ever seen it
Some have a special socket and the lamp shorts internally when it failsYes, but if I recall correctly, each fixture has a saturating-core transformer so that all the other lights remain lit when one burns out.
