AL feeder connect to CU bus bar
anbm
TX
Designer
Thought incoming AL wires that feeds an electrical panel won't work well with CU bus bar, the bus bar must be dual rate (AL/CU).
Or bus bar can be CU but wire lugs must be dual rate (AL/CU)?
The AL wires are connected to the lugs. If the lugs are suitable for AL you are good.
