NEC 2017 210.70(A)(2)(2) requires a wall-switch controlled lighting outlet for exterior lights. I'm debating whether making the switch or the lighting fixture controlled by Alexa has any merit. Even if it is desirable, is it allowed?
We say, "Alexa, turn on plug one,
I tell Alexa thank you sometimes. Just to be polite.Did you know that you can re-name the default "plug one" name to anything you want?
"Alexa, turn on the lamp".
-Hal
Saying "thank you" is not enough. You have to first state the name.I tell Alexa thank you sometimes. Just to be polite.![]()
I have a cheap 'smart' switch from Best Buy, it still has mechanical contacts as well. Now I have outdoor house lights that are on an 'astronomical' timer that never needs adjustment for daylight saving.NEC 2017 210.70(A)(2)(2) requires a wall-switch controlled lighting outlet for exterior lights. I'm debating whether making the switch or the lighting fixture controlled by Alexa has any merit. Even if it is desirable, is it allowed?
I have her set so i can give a follow up command without the wake word.Saying "thank you" is not enough. You have to first state the name.
I just did a test. I first said, "Alexa, what is the time." After "her" reply, I said, "Alexa, thank you." Then Alexa said, "You're welcome. Your kindness really gives me a charge."![]()
How, please?I have her set so i can give a follow up command without the wake word.
OMG my GF does that it drives me nuts!!I tell Alexa thank you sometimes. Just to be polite.![]()
Because your GF is polite?OMG my GF does that it drives me nuts!!
Mine too, "It's a machine" "You say thank you to the coffee maker?"OMG my GF does that it drives me nuts!!
LOLWhen my kids learned 'Alexa, tell me a fart joke....' sigh
What I say to machines can't be repeated in a forum. And ever since I started working at IBM a few decades ago, I've called each computer I've dealt with a "machine". IBM went out of its way to not talk about computers as if they were human. For example, data wasn't kept in memory, it was kept in store.Mine too, "It's a machine" "You say thank you to the coffee maker?"
