All outlets & switches have 120 volts but not working
shjohnson1996
New User
Maryland
HVAC Tech
I have 4 outlets, 1 GFCI, and 3 light switches on 1 circuit (everything within amp spec for the breaker). I get 120 volts to each receptacle....120 from hot to ground. GFCI is brand new, wired directly the same as one prior. Am I dropping a neutral in one of the receptacles in the circuit? before popping open the boxes, would the correct thing to do is to ohm out the outlets? as in test for continuity between neutral to ground. If there is continuity that means missing neutral at that receptacle?
Thanks
Try diychatroom.com
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
