all purpose mc
Used It
Used It
Not sure what he question is. We have used it since it came out, just make sure you are using the correct fittings for the cable - there are hundreds of them - and use self grounding devices. Saves the time on making up the grounds as advertised. Pricing is not that much different that standard MC - actually if you think about it, the cost should be less, aluminum g#10 vs. #12 THHN copper has to be cheaper.
