when using romex cable when there are multiple cables entering the same nm switch box how should the grounds be spliced together as well as terminate on all devices. I will use a specific example: when six type nm cables enter a three gang plastic box where one double switch and two single pole switches will be installed. Is it ok to splice the six plus the three ground wires for the devices under one wirenut. Or do they make a green wirenut that allows mulitiple grounds to come out of it and if they do than there must be different sizes. I cant stand looping the ground thru mulitiple devices as one continous wire.
