Open Neutral
- Inside the Beltway
- Engineer
{A fork from 13,800}
Yes, but... In talking with PG&E, you have to wonder...
See their electric meters do the mesh scheme, and they have regular pole-mounted nodes where they transfer to the cellular data to send the data upstream. You don't need all that many nodes that way.
Easy as pie, they have ample electricity in the meter. Their gas meters, however, use a lithium battery good for a few years. They do NOT send data to the nearest electric meter. Oh no, they need enough transmitter power to reach a node directly.
And in rural areas, where there are no nodes? They had no plans for mobile interrogators in cars; just park and walk to each meter.
I am curious about the contactors. Such also makes sense for easing the startup load when recovering from blackouts. But I wonder what design they are to NOT have large continuous currents? A mechanical latch with a 2nd, small hold-on coil maybe?
Beyond even that, current "smart meters" use their wireless data communications capability to form themselves into a mesh network where each meter is capable of relaying the data of other smart meters until the data reaches a wireless collection point in the utility network and makes the transition to another communications channel all the way back to the central office where it is noted by the computers.
Not even a drive by is necessary except perhaps in low density/rural areas.
And, as has been noted in other threads, with that also comes the great power to remotely turn off a contactor contained in the meter and disconnect your power. Not good enough for a safety disconnect, but perfectly good for billing enforcement. AFAIK they have not gone the extra mile to install a large contactor for CT based meter installations.![]()
