Drives Service & Support
> 1336F > Fault Finder
Fault Number: 05
Fault Display: Overvolt Fault
Fault Name: Overvolt Fault
Description: DC bus voltage exceeded maximum value.
Corrective Action: The following troubleshooting steps will attempt to figure out why the bus voltage of the drive went above:
405V dc for 200-240V drives
810V dc for 380-480V drives
975V dc for 500-600V drives
The first item to check is the incoming line voltage. This fault will occur if the line voltage goes over:
285V ac for 200-240V drives
570V ac for 380-480V drives
690V ac for 500-600V drives
Any incoming line swell above any of those points with the drive sitting idle will result in a fault 5. If your incoming line voltage sometimes can climb that high, then either a retap of your transformer to a lower voltage may be necessary. A DC brake may also be installed on the drive to burn off any excess DC voltage.
If the drive is running a motor, then the motor may be in a regenerative mode, which means the motor is spinning faster than the drive is commanding it to go. This is a common occurance with higher inertia loads such as fans and flywheels. This regeneration will feed back into the drive, and pump the bus up to unsafe levels, which will trigger an overvoltage fault.
If you are unsure of what the drive was doing at the time of the overvoltage fault, parameter 146 (Fault Status 1) will be of great use. We will be particularly interested in bits 4 & 5, which is accelerating and deceleration, respectively. If the fault occured during a decel, then regeneration will most likely be the issue.
To cure overvoltage during decel, the first thing to try, if possible, is to extend the deceleration time using parameter 8 (Decel Time 1). If extending Decel time does not help, or is not a viable option, then a dynamic brake will be your next best option. A DC brake is a resistor that hooks to your DC bus, and when the bus voltage gets high enough, it turns on, and absorbs voltage from the DC bus effectively reducing the voltage level. it turns back off when the voltage reaches a safe level. A mechanical brake on the load will also help prevent overvoltage faults.
If you have a load that is in regeneration often, then a regen drive may be the best option for you. A regen drive will take all that extra energy fed back into the drive, and puts it back on the AC line, reducing energy costs, instead of burning it up as heat as in a DC brake. Contact your local AB office or distributor for more information.
