Allocating lines from my 3P breaker
GM489
New User
Fremont, CA
Chemical Engineer
I have a 480V 3P-Y breakerbox at my facility capable of 225 A. Most of them are 3 breakers with 1 switch for all three (running 2 industrial ac units and 2-208V transformers, 36 A incoming).
One set of three breakers has three switches, one per breaker. The labels indicate that only the first two are being used to power lighting in the facility. The third has no label but is switched on.
Is it possible for the lighting in our facility to be powered by two out of three phases? If so, is it more likely that each is being used as a 277V 1P? What are some ways I can check this?
If the third breaker is unused, would it be treated as 480V or 277V? Can individual legs be tapped as 1P, and if so, can I pull a much larger amperage from one vs the other two?
My office requires one outlet of 240V, 30A. If possible to tap the aforementioned leg, and step it down to the needed condition? My alternative is to sacrifice 3 of my 208 outlets and step them up.
Thanks
A single pole breaker from a 480V Wye system would be 277V, line to neutral. If you want to step up to 240V, you are better off using a 2 pole breaker and going with a standard 480-240V single phase transformer. Your electrician will know what to do.
That said...
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the Report Button at the lower left hand corner of the post
