Newwave
New member
- Alliance, Ohio, USA
looks fine to me except for the wire without a lug.
I believe he's referring to what looks to be a ground stud above the one on question. There seems to be a bare solid conductor coming from under something on the right that is wrapped around the stud.
-Hal
When a stud has appropriate combinations of washers, it can be rated for use with bare wires (solid only or both stranded and solid). The combination of ring terminal and bare wire is more problematic.I believe he's referring to what looks to be a ground stud above the one on question. There seems to be a bare solid conductor coming from under something on the right that is wrapped around the stud.
-Hal
