als
New member
- gays mills, wisconsin, usa
can test insruments such as stroboscopes, tachometers, pyrometers,flowmeters, etc. be safely used in a class I hazardous environment?
While these instruments are not part of the premises wiring and not technically under the scope of the NEC, it is NOT recommended to use them unless they are specifically identified for the location.can test insruments such as stroboscopes, tachometers, pyrometers,flowmeters, etc. be safely used in a class I hazardous environment?
It has been removed in the 2014 NEC.Portable or transportable equipment having selfcontainedpower supplies, such as battery-operated equipment,could potentially become an ignition source in hazardous(classified) locations. See ISA-RP12.12.03-2002,Portable Electronic Products Suitable for Use in Class Iand II, Division 2, Class I Zone 2 and Class III, Division 1and 2 Hazardous (Classified) Locations
When will people realize this forum is not for arguing or to establish a persons competence.....
Maybe reacting to a post which was deleted before most of us saw it?i'm missing something here... there are two posts to the OP, and neither was arguing
or questioning anyone's competence.
the third post simply suggested to listen to bob, which is pretty good advice, as he knows his way
around classified occupancies pretty well, and mentioned that 3 volts can be a pretty fair source
of ignition.
