Angel Electric
- OBX, NC.
I was called to fix a motor on a duel motor compressor. One motor hwd failed and could no longer be run in the settup . I had to bypass all aux sw. And relay which shifts the primary starting motor from the left or rt..
The compressor tank has two motors mounted on top with two pressure sw'sand an alternating starter relay btwn the two... Ideal each motor is made to be the primary one time after the next... This was very difficult to rewire.
Is there any good references out on the market which will help with wiring motor controls and starter combimation... Here is a pic....
