Rick 0920
- Jacksonville, FL
- Electrical Instructor
A lot of contractors are using these in homes wired with aluminum conductors. These houses used the smaller metal switch boxes where the back of the boxes sloped thus limiting the cu. in. capacity of the box. This is big business as they are instilling fear in their customers of the problems involving aluminum wire. IMO, these products take up more room in the box than a wirenut because of the way you have to terminate them. Have any of you used these and do you think they fall under under the category of "small fittings" in the box fill calculations? In the few instances that I have seen, If they are not calculated, (which they are not) it makes it incredibly difficult to install devices even though the calculation determines it is code compliant.
