yeah, it's a very corrosive environment. Do they make aluminum strut straps and aluminum unistrut?Probably not unless there was some other factor like they're in a corrosive environment.
Yes they do. If this an area that steel raceways are not suitable why would you consider using steel supporting hardware?yeah, it's a very corrosive environment. Do they make aluminum strut straps and aluminum unistrut?
It's an old installation from years ago my boss noticed it. He wants us to change the straps and the unistrut.Yes they do. If this an area that steel raceways are not suitable why would you consider using steel supporting hardware?
In normal installations steel and aluminum is mixed frequently.
I guess it was mixed because maybe he ran out of aluminum straps and strut? So you're saying mixing aluminum and steel is done frequently? I can't understand why it would be done. If you running in aluminum, there's a reason.It's an old installation from years ago my boss noticed it. He wants us to change the straps and the unistrut.
I did one job that specified aluminum just because the engineer thought the labor would be cheaper.I guess it was mixed because maybe he ran out of aluminum straps and strut? So you're saying mixing aluminum and steel is done frequently? I can't understand why it would be done. If you running in aluminum, there's a reason.
Not necessarily. Sometimes the reason is just 'that's what they had' or 'it was cheaper'. Particularly true of FMC, more than other types conduit. But with FMC aluminum is definitely mixed with steel hardware all the time.... If you running in aluminum, there's a reason.
If it's an old installation, you can see at a glance whether dissimilar-metal corrosion is a problem.It's an old installation from years ago ...
Think about die-cast aluminum fittings, aluminum hubs, steel MC fittings/straps with aluminum MC.I guess it was mixed because maybe he ran out of aluminum straps and strut? So you're saying mixing aluminum and steel is done frequently? I can't understand why it would be done. If you running in aluminum, there's a reason.
Die cast fittings are zinc.Think about die-cast aluminum fittings, aluminum hubs, steel MC fittings/straps with aluminum MC.
If the existing hardware is in good condition there is no reason to change it. If the hardware is badly corroded then a suitable replacement should be installed.
Obviously he didn't have any field experience.I did one job that specified aluminum just because the engineer thought the labor would be cheaper.
where I work is extremely corrosive in certain areasFWIW aluminum with stainless fasteners is standard in the solar industry for array racking exposed to the elements. It even gets listed for grounding. I think someone is overreacting.
